- Mobile Apps
- Android
- Mobile web editors
- Presentation Editor web version
- Adjust chart settings
Adjust chart appearance
Currently, you can adjust the appearance of an existing chart in the presentation.
To do that:
- select the chart by tapping it,
- open the chart settings panel by
- tapping the
icon at the top toolbar, or
- tapping the Edit option in the pop-up menu,
- tapping the
- tap the necessary menu item: Design, Arrange, or Align. Use the
arrow on the left to return to the previous settings section.
The Design section contains the following four tabs:
- TYPE - to change the current chart type (line chart, column chart, bar chart, area chart, pie chart, point chart, or stock chart). Swipe up to see all the chart types and tap the one you want to apply.
- STYLE - to change the current chart style. Swipe up to see all the available styles and tap the one you want to apply.
- FILL - to change the chart background fill by selecting a solid color. Swipe up to see all the palettes and tap the necessary color on the Theme Colors or Standard Colors palette. If you don't want to use any fill, tap the
icon on the Standard Colors palette.
- BORDER - to adjust the chart border Size by dragging the slider and select the border Color on the palette.
The Arrange section allows to set the selected chart position as related to other objects when several objects overlap each other. To learn more, please refer to the Manipulate objects section of this guide.
The Align section allows to align the chart on the slide. To learn more, please refer to the Manipulate objects section of this guide.
- close the chart settings panel by tapping the
arrow on the right.
Remove the chart
Select the chart by tapping on it and proceed in one of the following ways:
- tap the Delete option in the pop-up menu, or
- open the settings panel by tapping the
icon at the top toolbar, swipe up, and tap the REMOVE CHART button.
